1 - 1 of 1 Posts
Special Introductory Pricing:
2008-2014 Dodge Challenger Headlight Conversion just $89.95 (Low Beam & High Beam) ORDER HERE
2015-2019 Dodge Challenger Headlight Conversion just $89.95 (Low Beam & High Beam) ORDER HERE
ORACLE Lighting S3 LED Conversion Bulbs instantly provide 3200 Lumens of Crystal Clear 6000K light output. The electronic components of the S3 Headlight bulbs are housed in a sealed waterproof heat-sink design, eliminating the need for external drivers and cooling fans. The lack of LED driver makes it ideal for fitting behind the stock cap of the late model Challenger.
The CSP (Chip Scale Package) LED Chip Design features a small package size but high intensity volume per unit with less heat value resulting in industry-leading Luminous Efficacy (science talk for “Best Bang for your Buck”). This new low-profile design reduces common bulb fitment issues for an easy Plug & Play DIY installation.
Product Specs:
• Operating Voltage: 12V/24V
• Color temperature: 6000K
• Material: 6160 aluminum
• PCB: Double Layer Copper
• Current Demand: <1 Amp
• Warranty: 1 Year Limited
• LED Chip Type: CSP
• Brightness: 3200 Lumens
• Power Draw: 12W / Bulb
• luminous Efficacy: 130lm/W*
*Industry-Leading Efficacy Ratio
1 - 1 of 1 Posts
