We currently have programs for both the 5.7 and 6.1 Hemi controllers, 6 speed and automatic. Here is some information on the calibration.
Cooler engine fan on temp
Cooler transmission overheat on fan temp (auto)
Firmer Shifts
No stall air/fuel torque management
No stall timing torque management
Modified shift torque management (auto)
Modified tip in spark retard
Modified throttle pedal/blade filter
Modified Down Stream o2 sensors algorithms
Modified A/C off at WOT feature
Modified knock sensor algorithms
Modified closed to open loop time
Modified closed to open loop fuel enrichment curve
Modified P/N rev limit
At this time we can only offer these programs installed on your controller. Turn around time is 2-3 days. $600.00. These are not Diablosport created tunes.
What is it for the 6 sp srt 6.1s that you have and how do we program? Predator is still on hold as far as I know. for the 6spds...
thank you!
Dave,
We can provide calibrations for the 6 speed 5.7 and 6.1 Challengers. You will need to ship us your computer and a list of modifications. We can ship your controller back in 3 working days.
Thanks!
how much hp can you get out of 5.7 with this tuner safely without voiding anything and how does it work will i need to do something everytime i drive? all new for me
I'm with Skunky. I've got the Predator waiting for the programming. In the meantime I've installed MBRP cat backs and a K&N CAI and the 180 thermostat. Do you have the program for the 5.7L auto adapted for the mods? If so, how much does it run?
We do provide calibrations for the 09 5.7 and 6.1 stick shift cars with the bolt on mdifications you describe. They include all the changes noted above.
We see about a 20hp increase between 3000-5000rpm. At this time we need your controller to calibrate and can turn it around in about 3 working days.
The biggest benefit is how the car feels when you drive it.
