Anyone change a heater core on these cars yet? What's involved? I have the $70 part. Is it a pull the whole darn dash or what? Any step by steps out there? Thanks for any input. I'm considering a you tube video creation while I do it to help others out there. Also, I have the ESP light on when making a right. Any videos/pics on the quick fix on this? I know there is something to move on the steering column to fix it.
Thanks folks...
Jim
Shade tree mechanic 20 yrs...
I have not removed the heater core but the service manual makes it sound quite involved including yes, removing the dash.
it would require pulling the dash - the heater core is in the center, just above the trans tunnel / center console.
It would be a two person job to unbolt the dash and lift it out - likely requires pulling the steering wheel to have enough room to get the dash assembly out.
Thanks for the prompt answers. Anyone know of where I can get a download to see how this all goes together?
24 - Heating and Air Conditioning/Plumbing/CORE, Heater/Removal
REMOVAL
Labor Operations: Click to display a list of Labor Operations associated with this procedure
WARNING:Disable the airbag system before attempting any steering wheel, steering column or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable and wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
WARNING:The heater core tubes are not serviced separately from the heater core. The heater core tubes should not be repositioned, loosened or removed from the heater core. Failure to follow this warning could result in a coolant leak and possible serious or fatal injury.
NOTE:LHD model shown. RHD model similar.1.Disconnect and isolate the negative battery cable.2.Remove the HVAC housing assembly (9) and place it on a suitable workbench (Refer to 24 - Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal) .3.On LHD models, remove the blend door actuator (1) from the driver side of the HVAC air distribution housing (2) (Refer to 24 - Heating and Air Conditioning/Controls/ACTUATOR, Blend Door - Removal) .4.Remove the two screws (8) that secure the flange (7) to the front of the HVAC housing near the dash panel and remove the flange.5.Remove the screw (5) that secures the heater core retaining bracket (3) to the driver side of the HVAC air distribution housing and remove the bracket.6.Disengage the heater core tubes (6) from the HVAC housing and carefully pull the heater core (4) straight out of the side of the air distribution housing.
24 - Heating and Air Conditioning / Distribution / HOUSING, HVAC/Removal
HOUSING-AIR DISTRIBUTION
WARNING:Refer to the applicable Warnings and Cautions for this system before performing the following operation (Refer to 24 - Heating and Air Conditioning/Plumbing - Warning) and (Refer to 24 - Heating and Air Conditioning/Plumbing - Caution) . Failure to follow these instructions may result in possible serious or fatal injury.
WARNING:The heater core tubes are not serviced separately from the heater core. The heater core tubes should not be repositioned, loosened or removed from the heater core. Failure to follow these instructions may result in a coolant leak and possible serious or fatal injury.
NOTE:The air distribution housing must be removed from the HVAC housing and disassembled for service of the mode-air and blend-air doors.
1.Remove the HVAC housing assembly and place it on a suitable workbench (Refer to 24 - Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal) .2.Disconnect the HVAC wire harness (1) from the mode door actuator (2) and the blend door actuator (3) located on the driver side of the air distribution housing (4).
3.Remove the blend door actuator (1) from the driver side of the air distribution housing (2) (Refer to 24 - Heating and Air Conditioning/Controls/ACTUATOR, Blend Door - Removal) .4.Remove the two screws (8) that secure the flange (7) to the front of the HVAC housing (9) and remove the flange.5.Remove the screw (5) that secures the heater core retaining bracket (3) to the driver side of the air distribution housing and remove the bracket.6.Disengage the heater core tubes (6) from the foam seal at the front of the HVAC housing and carefully pull the heater core (4) straight out of the side of the air distribution housing.
7.Remove the two screws (1) that secure the air distribution housing (2) to the rear of the HVAC housing (3).8.Tilt the top of the air distribution housing rearward to disconnect the distribution housing from the tab-and-slot type retainers located at the bottom of the housing.9.Disconnect the air distribution housing from rear floor distribution ducts.10.Remove the air distribution housing from the vehicle.11.If required, disassemble the air distribution housing (Refer to 24 - Heating and Air Conditioning/Distribution/HOUSING, HVAC - Disassembly) .
