OK so i've looked thru the threads and googled the crap outta this and can't find what i need. I've removed all of the plastic rivets and everything else holding my drivers side front inner fender liner in place but there's one large piece that looks like the brake lines feed into. It looks like some type of big square clip but how do you remove it in order to free that drivers side inner fender liner? Everything i've found mentions only the couple of bolts and the plastic rivets, nothing mentions this thing.
Have you checked the online chilton's manual?
Discussion Starter · #4 ·
Thanks, this manual was very much needed !!
Problem solved!
Discussion Starter · #5 ·
Do you have the wheel off?
I did remove the wheel this morning and found the inner fender had been replaced previously and had been glued to the metal surrounding the small sensor thingy. Once I was able to yank the glued section free I realized it was an aftermarket inner fender and all i should have had to do was unbolt the sensor from behind the brake hub and thread it thru. Thanks for the advise!
