1 - 19 of 19 Posts
2013 Dodge Challenger R/T 6 speed
I’m looking to buy a set of long tubes for my 2013 Challenger. The only mods done to the car are CAI, Barton shifter, 180 degree thermo, Diablo can tune on 93 and Mopar Stage 1 lowering springs. I plan on swapping the intake to a 392 intake soon, not sure which diameter primary headers I might need. ( later down the road I plan on a custom grind cam)
1-3/4"
2010 R/T Classic 6M
1 7/8", won't hurt power at all and will help when you get a cam down the road as well as anything else you may add
2010 R/T Classic 6M
I should add I ran 1 ⅞ on my car for a year with same setup you have now and it ran great, picked up power thru the whole curve, just make sure you get a custom tune for the headers. The fact the heads flow so well is what makes the bigger header a good choice. And I'm glad I did cuz a year later I have a cam and supercharger so I definitely need the 1 7/8
Discussion Starter · #6 ·
Yeah I know I’ll need to get a tune for the headers, ad to who I’m going to use for the tune I’m unsure as OST the one company I want to go through uses H.P. tuners. I might go with a hemi fever tune
This just helps me in justifying a trip up to Stainless Works to get a set of their headers 😁
2010 R/T Classic 6M
Stainless works are good. Any of the hemi tuners you always hear about will be good, as long as the logger is also good. I personally went with Diablotoona but hemifever is good as well.
I went with OST and could not be happier. They use Kooks, I am happy with them. I also got their Rumbler cam. It is awesome!
I want to go with their Big Daddy cam 😁 I just know they have yet to install one on a 5.7, but I’d really want chop and performance with what I’ll be paying them
I got the quote for that, after everything required was over 11k and if there are clearance issues will go with a Rumbler cam anyway.
2010 R/T Classic 6M
11k for a cam!? :eek: Does it need over bore and valve reliefs from high lift to work of something? That's crazy
l
You have the custom ground cam, kooks headers, catted mid pipes, torque converter, 180 degree t-stat, Labor, Tuning and all the things required for tuning. Well worth it in my book.
I have between 8 and 9k in my Rumbler install and I cheaped out and did not get the converter. Well get it the first time. I am waiting for the quote to get the Converter and electric cutouts done but that will not happen until next spring.
2010 R/T Classic 6M
Hmm I guess when you add in little things I already had like a programmer and stuff it adds up. Are they the green cats or regular high flow? Cuz I know those green cats are expensive but worth it from what I hear
Yeah even with the other stuff, no thanks.
1 - 19 of 19 Posts
