I removed the front wheels and there were plenty of material left on the pads... didn't remove the rear. Told me labor was $300 Parts were $1,400.
I DO NOT DRIVE THIS VEHICLE HARD.
I told them I would be there to pick up my vehicle... It is a leased vehicle that is due back in 11 months (July 2020).
Any recommendations on O.E.M. replacement parts websites/stores (Michigan) will be appreciated. I can do the work myself.
Thanks
fyrdude asks the right questions. Absent a wear sensor warning light on or absent any signs of excessive brake wear -- a "big" lip around the rotor outer diameter or pads backing plates getting dangerously close to the rotors why did you have the car in for a brake hardware replacement estimate?
Even if the brakes need doing, I don't think you can chose to not do this. With a leased car I don't think you can drive the car on worn out brakes. Even if you don't care about the car in this regard I think you would care about your safety, those of your passengers and people that share the road with you.
As for how you drive the vehicle...
One might be surprised at what it takes to slow 4000+ lb car. And braking "easy" can be harder on brakes that one might believe.
What can happen is the slow roll up to a stop with the brakes applied heats the hardware up and keeps the hardware hotter longer and the pads in contact with the rotors longer. Heat is the enemy of brake hardware. This equals more wear.
A slightly more aggressive braking action -- while still of course maintaining suitable control of the car and not in any way causing any upset to any vehicles in the vicinity of your car -- can shed speed then give the brakes time to cool some with the pads
not in contact with the rotors.
