Hello, anybody running 12lbs of boost or more on a stock exhaust manifold??? Any issues. I am currently at 10lbs and i have made the decision to make one more jump to 12lb. The plugs i currently am running are irridiums 2315. I would change those to one more step colder. To help with the increased IAT in the combustion chamber. I am not interested to change to aftermarket headers if at all possible
2. Fuel system : Also i am running ford blue 80lb injectors , 392 fuel pump with boost a pump: Anybody running boost a pump with 12lbs of boost or more without issues. Thanks in advance to anyone who responds with help.
2015 SRT
My 2015 SRT392 has factory manifolds on 12lbs, no problems here. They are the same as a Hellcat. It's probably leaving a few horsepower on the table but couldn't justify the cost. If you have a 5.7, get the 392 manifolds and mids.
Sent from my SM-N920R4 using Tapatalk
Thanks , i have a 6.1 l intake manifold are the flow numbers similar to your 392??? Also what fuel system are you running
2015 SRT
I am running an Arrington single drop in fuel pump. It's good to about 700whp or so.
If you are talking intake manifolds, my whipple replaces that. The exhaust manifolds on a 6.1 are similar to a 392 but not the same yet still flow well but not as well as a long tube header.
You will be ok with the stock srt headers but I would ditch the 392 pump and bap and get either the Arrington or MMX single fuel pump with upgraded fuel lines
