Tried 2 plug in an iPhone car charger into the 12 volt but it didn't work. The one under the armrest works tho. The car has 45 miles on it.
The one under the armrest is always "live." The other needs the car to be running before it gets juice. If your car wasn't running, that would be the reason.
Did you have the key on. The one in the console is hot all the time and the one you can see is only hot when key is in acc or run position.
I've tried the key in every position. Does the car need to be running for a few minutes or something?
No mine is hot as soon as you put the ignition on. Your Ipod plug might have a delay. Do you have anything else you can plug in there and see if it comes up right away?
You might want to look at fuse 18 in the trunk. It's called selectable and might be what powers it. It should be yellow (20 amp).
