1 - 3 of 3 Posts
Hi,
I was replacing the headlight bulbs with some LEDs when I went to pull out the bulb it was only wires, I stuck my fingers inside to feel around and didn't find anything. So was wondering if there would be any reason there wouldn't be a light bulb? Also when I turned the lights on the headlights turned on fine so I am not sure what is going on. If anyone knows I would appreciate it.
Thanks
edit: Its an LED ring :p
1003258
If you unplug that wiring harness in the pic, does one of the headlights then fail to illuminate when the headlights are turned on?
Reactions: BLACK_
Can you post a picture showing the wire harness connector? That doesn't look like the headlight bulb which has tabs to turn it to lock.
Not sure what the turn signal light looks like on a 2013
Reactions: BLACK_
1 - 3 of 3 Posts
