13 SRT8 no catch can
890 Views 33 Replies 12 Participants Last post by  Xylander
Hey everyone,
I've been wanting an SRT for a very long time and finally am getting one. I'm a car hauler for a certain nationwide used car dealer and have the opportunity to purchase cars they are going to wholesale for basically wholesale price. To make a long story short I'm in the process of doing just that on a 2013 SRT8 Core with 82k on it. It's in great condition still, has passed a used car safety and mechanical inspection, which is a requirement for the company, and for the price($17k with tax and reg) I can't pass on the chance to finally own one.
The previous owner did not put an oil catch on it and I always see it recommended here. So my questions are should I be worried about it and should I throw one on ASAP?
Thanks!
1 - 20 of 34 Posts
I wouldn’t be worried about it. Toss one on if you want.
There are a lot of differing opinions on this. Dodge doesn’t think they are necessary or they would be included. I am in the “get one” camp. I install a catch can immediately after purchase. I do my own oil changes and routinely drain blow by oil from the can. It is usually 1/3 to 1/2 full. I would recommend you do the same. If you search this site you will find a wealth of information regarding catch cans. Let us know what you decide.
Not a dealbreaker. If you are worried about it, you can always have the internals cleaned but I have no idea how much that is it how much of a pain that would be. I think you're more than safe, though, just know that you can always do a thorough cleaning and then throw on a catch can.
Put a catch can on once you buy the car. Definitely put a can of fuel system cleaner in it to remove any nasty build up.
Reactions: 2
With 82K miles it has sucked quite a lot of oil vapor into the intake manifold, but keeping anymore from getting in there is a good thing.
Reactions: 2
Hey everyone,
Thanks!
Catch cans on a naturally aspirated engine are a complete and total waste of money. Boosted engines, slightly different story.
Reactions: 2
It is not to late to install a catch can. It is cheap insurance for your engine.
Read the following article:
(480) Catch Cans | Page 3 | Dodge Challenger Forum (challengertalk.com)
1. Get a carfax or equivalent report regarding # of owners, oil changes, tire changes, etc. Worth $40 in price and good for 3 months.
2. I prefer not to see a catch can on any used car I buy, so I consider that a plus. Every used car I see with a catch can had other things done to the car. Typically muffler mods, but there may be things you can't see like cam, or injectors, or God knows what.
3. It would also be good to get a scanner to scan for codes that don't throw a check engine light. Even an inexpensive one($40) should give you some basic information.
Reactions: 1
I have to disagree, mine captured plenty naturally aspirated before it was supercharged.
My wifes 3.6L V6 G/T captures almost twice what my 5.7 did naturally aspirated, and about equal to it being supercharged, and I am glad I got hers installed at very low mileage. If any naturally aspirated engine needs a catch can it is definitely the V6 Pentastar.
I have catch cans and zero other mods but a skip shift eliminator on the manual and no other mods on the autos.
I’ve had numerous intake manifolds off that drip in oil to prove a catch can is extremely worthwhile. My TVS2300 GTO, NA GTO, Challenger, and Charger all have catch cans. They each catch roughly the same amount of oil after the same miles driven.
Oil vapor coating the intake manifold and the back of the valves isn’t a great thing and manufacturers know it. They don’t care as they are in the business of selling new cars; not the longevity of them past the warranty. The PCV systems are meant to control emissions by burning crankcase vapors. That vapor also reduces the effective octane rating of the gas charge into the combustion chamber which can potentially cause detonation/knock; especially as the mileage increases.
Bottom-line: They work and are beneficial for all vehicles.
Reactions: 1
Ignore the people that say they are a waste. I feel like they just say that to stir up trouble and then everyone always explains how they are useful. Same pony ride every time...
  • Helpful
Reactions: 2
you really don't know, maybe the previous owner had a catch can & removed it before it was sold....
I have one on all my mopars, & I assure you they work
Yes, engines lift oil. They get behind the valves. Yes, NA engines lift oil and oil does in fact reduce the octane rating of the combustion chamber. Context, though, is key here. Do you know how much oil soot it takes to gum up a valve? If you're just talking oil deposits, on an engine running correctly, it would take a half million miles or more to build up any amount of appreciable deposits. The majority of these cars will never see 200,000 miles. Now, the real killer on valve deposits is over-rich running engines and/or engines running with a misfire caused by mechanical issues, bad gas, etc. You can create more deposits in a month with a bad or poorly gapped spark plug than you can over a lifetime of normal oil deposits.
NA engines can lift a little oil via the dirty side of the PCV. I had a catch can on a 392 T/A for a couple of years. In that time, the J&L oil separator caught maybe a 1/4 cup of oil over 2 years of daily use (28k miles). Boosted engines can lift a lot. On my Redeye, I can catch a teaspoon of oil every time I go WOT for an extended period. I can fill a catch can in 5,000 miles. This is caused by many times elevated crankcase pressures vs what you see in an NA engine. Boosted engines CAN lift enough oil to negatively impact the octane rating in the combustion chamber. No stock Mopar NA engine can. The 392 has a 72.4cc combustion chamber volume. To negatively impact performance to the point you could feel/notice it, you'd need about a 5% total volume of oil in the combustion chamber... which comes out to about 0.9 ounces of oil present in the entirety of the top end of the engine on the ignition stroke to achieve performance degradation. This is more than what most 392's see in 3 months of use in the bottom of the catch can. In comparison, my Redeye can lift this much oil in 1 WOT pull from 80-150mph. In my case, while it's possible that I could get enough to cause the car to briefly pull timing at the top end of 3rd gear, it's still mathematically remote that it'll lift enough in a finite period of time to cause the PCM to pull timing.
With the 392, it's impossible for it to lift enough oil to adversely impact the octane rating in the combustion chamber. This is doubly true for the 5.7L.
With older engines, even those with high miles, they'll have valve deposits, but almost all appreciable deposits are caused by unspent fuel or additives, not oil. For an engine that has ran perfectly for 50k miles or more, you might have 1-2 mils of carbon coating on the back of the valve. It's thin enough to easily scrape clean with the back of your fingernail. On almost any internal combustion engine, it would take millions of miles before oil deposits gummed up a valve on an engine running normally. This is because oil in the dirty side of the PCV is kept in aerosol form (vapor). It typically doesn't stop or cling to anything and passes harmlessly out the exhaust. When you DO see visible oil, that's from condensation caused AFTER you turn the engine off. Over time, you'll see what looks like tiny pools of oil in the throttle body, maybe in the intake runners. Once that oil vapor condenses, it'll usually stick in there and hang out. Heavier materials are generally pushed to the outside of the runners, for example, and will stay long-term and build up over time, giving an untrained eye that the car is lifting a bunch of oil... but that's usually months or years worth of accumulation.
Catch cans are then a bit of a self fulfilling scam of sorts. They put a catalyst in the PCV system that forces the oil aerosol to condense and fall into the catch can. Thus, removing "harmful" oil. Without that catch can though, that would have never condensed into liquid oil at any time during the engine's operation. Low volumes of oil aerosol doesn't gum up anything. Now, under very high pressure (aka compression stroke in the combustion chamber), it can force that aerosol into a liquid, briefly. This is where, again, boosted engines running much higher pressures caused by forced induction can benefit from a catch can. They do lift more oil and their internal combustion chamber pressures are much higher. But, as soon as the spark fires and at the end of the power stroke, the exhaust valves open and that oil is turned back into an aerosol. At no point is there ever any liquid oil in the cylinder on the intake or exhaust stroke if the engine is running correctly... so there's not any oil that's gumming up any valve seats. Almost all gunk buildup is entirely caused by unspent fuel and additive deposits.
Thus, a catch can does well at solving a problem that doesn't exist on 99% of all cars on the road. Unless the car is running high boost levels, the engine is just not going to lift enough oil to ever cause an issue.
That being said, a catch can won't hurt anything if it's used. Folks like to say it's peace of mind and all, but the reality is pretty simple. They don't do anything on NA cars. Nothing that the engine already doesn't do for itself. The only damage done is the $150 or so a person pays for the catch can. I'm not going to sit here and tell folks to not get one. If they want one, it's not going to hurt anything. You just don't get much benefit either, other than it looks like they added a mod to the car for when they go to Cars and Coffee.
See less See more
Reactions: 5
It is really not pure oil. It is a toxic brew of oil, gasoline, water and acids. The only reason that the vapor is not vented into the air (like the pre-mid-60s) and burned instead, is emission laws.
Reactions: 1
Well, all that combination of "stuff" is still vented into the air and burned, it just goes through the catalytic converter first now.
ive got one on my ram and srt. theres dirty crap in both when i cnge oil. especially the ram. 5k and its half full. now is it going to double the life of your motor? hell no. but ask me if id dump the mess back in my motor. i knoe one thing thats fact. it doesnt hurt and its better money spent then some hokey cold air or throttle body spacer that cost more
Reactions: 2
The most important sentence in your catch can reply.
I think his engine was built a little smaller than ours. It was probably a car built for ants, it has to at least be least 3 times bigger than that!
I actually don't know what the chamber volume is at that point, but I couldn't resist.
Actually, it might be around there! Surprising...
1 - 20 of 34 Posts
