1 - 1 of 1 Posts
2019 Dodge 1320
Love the car but there was a noise from the rear seat delete area when turning hard left or right. Found that the back cover between the trunk and interior which is held on by 10 push pins two of them had fallen into the track that holds them allowing them to float inside the bracket making noise on turns. You have to remove ths base then pull on top edge of back to release the push pins. Looks like assembly line error. I did not take pictures but hope this helps.
1 - 1 of 1 Posts
