I'm needing to replace my tires on my 2014 blacktop edition RT plus. Does anyone's know for certain if I can run 255/45/20s on all 4 corners without issues or stick with the 245/45? Thanks
Cool, thanks to both of you!
2014 rt shaker
New SRTs run 275s on all 4 corners so 255s should be no problem
Srt cars have a different knuckle, caliper, and wheel (both size and offset) compared to his rt.
Also, 15+ cars have more clearance at the fender lip than the pre-15s do.
So whatever a 15 srt can run has little bearing on what his car can run.
However, a 255 will still fit on both his wheel and inside the wheel well.
Wow as long as we're not picking. The knuckle or caliper size has nothing to do with a bigger tire rubbing the fender.
But as you said I was still right.
