Does anyone have an idea as to what may be causing the #17 fuse in the rear distribution panel to blow upon instal, in my 09 challenger SRT8? Thanks in advance!
Thank guys, that’s what I found too. Would you guess that I need a new cluster then? Or would it be worth trying to find the short?
A simple test would be to "unplug" or otherwise disconnect the suspected device "cluster"...put the fuse in and see if it blows. If it does, you have a short in the wiring or in a connector that replacing the cluster won't fix. But with the cluster disconnected, the fuse does not blow, the short or overload is in the "cluster".
