1 - 4 of 4 Posts
ok I found a thermostat that is rated at 170 degrees. I know every one talks about going to a 180 degree thermostat. question is will the 170 work? I have a diablo so adjusting the fans are not a problem. Besides I can get the 170 for half of what the 180 costs....
AutoZone sells the same Jet 180 degree thremo under their own name for about $15. I had no problems with it on my ram
2009 R/T
You will throw codes and contaminate your oil with moisture and unburned fuel. Aluminum heads need heat for optimum efficiency and power. ie NASCAR engines NEVER run below 200.
1 - 4 of 4 Posts
