1 - 11 of 11 Posts
2019 Challenger Stars & Stripes Scatpack
Hey guys tried searching here and YouTube with no luck. I want to swap to quad exhaust tips on my new 19 pitch black scat pack. I know from searching it has a 2.75 diameter. Question is there is a clamp system that holds the tips on. Are these attached to the pipe/muffler? Or to the tips themselves. Trying to avoid taking a tip off until I have proper replacement s. Thanks
The tips clamp to a ball joint on the resonator outlet. They are tack welded in place. You should be able to break the tack and unclamp them. But be aware, there is little space behind the stock resonator to attach aftermarket tips. To get them correct and not stick way out usually takes some trimming of both, and welding on
Discussion Starter · #5 ·
Thanks as always A guy. I saw those only issue is I'm trying to black out and cant find them in black or any comparable ones in black.
I only posted them for comparison to the ones you suggested :)
2017 challenger scat pack jazz blue Hellcat air box, brakes , and wheels Trackhawk exhaust tips
Here is a oem quad black trackhawk exhaust tips. Mine are on order pricey but beautiful. Part# 6830689ab and 6830690ab
986652
They are direct bolt on using factory clamp straight to the resonator
Discussion Starter · #9 ·
Thanks again Turk just ordered. Can't wait to see them on the car.
2020 Challenger R/T SP Widebody 50th Ann. Edition in Frostbite
Hate to bring this back from the dead, but in the process of exploring options for just the tip (sorry, couldn't help it) I came across this thread and was looking at the parts. In case someone in the future does the same, I'm pretty sure the part numbers above are both missing a "5" in there. The Mopar parts listings for the Trackhawk tips (2018-2021) are showing part numbers #68306589AB (left tip) and #68306590AB (right). Left and right parts links:
1 - 11 of 11 Posts
