does any one know the part# for a 190° thermostat for our cars. ive been searching for days with on luck. i put 2 different 180° in(Jet and autozone) and kept getting codes.
thanks
Rob
thanks
Rob
they where set to 190 and 198, and got codes tried raising and lower them with the same resultsI had the same problem in an SRT8 but not in my R/T. the problem is not the thermostat it is the temp you have the fans set at. you need to reset the fans to 189 on the LS and 194 on the HS, check out HHP page and you should find it there.
whats the napa part number? the link doesnt bring you to a parti just found this on napa.com Store Locator | NAPA Online and ordered it. only problem is it doesnt have a Jiggle Pin any one no if bleeding the system will be a problem without it.
thm 381190whats the napa part number? The link doesnt bring you to a part
I would like to know how it fits and how it workes for you after you get it installed.thm 381190
Can someone post a link for that? Thanks.check out HHP page and you should find it there.
You can drill an 1/8" hole in the disk and it will work fine:smokin:i just found this on napa.com Store Locator | NAPA Online and ordered it. only problem is it doesnt have a Jiggle Pin any one no if bleeding the system will be a problem without it.
thanks ill try that it should be here this week. (ordered online) ill let you guys know if it worksYou can drill an 1/8" hole in the disk and it will work fine:smokin:
actually, they come stock with a 203 tstat (the Hemi engines anyway)FYI: the Challengers come stock with a 195 thermostat.
