1 - 3 of 3 Posts
I have a nice 70 ss camaro with numbers matching motor, trans, and correct 12 bolt rear end. the car has a ZZ4 gm motor in it now making about 400-450 hp. the car is a nice show/drive very fun car. 17 in the front and 18's in the rear. car has been lowered. shift kit in trans. have a set of original Z28 wheels to go with it. The a/c has been taking off the car but I do have the original comp.
[email protected]
919-274-4336
$25,000
So if its numbers matching, where is the original motor and what is it? What are the last 8 of the vin#, and what are the #s on the block pad of the original motor? Might be interested, but these are the first of many questions I would have. Feel free to PM me or I will do the same.
If you look at the sec pic and look under that work bench in the back ground the motor is under there. Yes the motor has the vin number stamped on the block next to the oil filter and the trans has it stamped on the pad. The SS 350 came with 300hp
thanks richie
1 - 3 of 3 Posts
