At 40,000 miles I have experienced my first part failure. I have noticed on several occasions a front end shudder when applying the brakes slightly from high speeds. I'm rather easy on brakes since I have an aversion to using them :browsmiley: so I could not accept that the rotors were warped. I've never had a set of rotors "warp". This morning I started investigating suspension components and while my assistant pushed and pulled on the front tires I observed play in the right front tie rod end. Probably 1/8" which when transferred through the knuckle, spindle, hub and tire probably is enough to cause what I've been experiencing. Slight drag on the brakes throws the assembly into a wobble type cycle. That's my thought process anyhow. To you suspension gurus, would I be correct in my assumption?
Thanks for your opinions.
