1 - 12 of 12 Posts
Picking out what long tube headers I want to go with from Stainless Works with catted mid pipes. Going to be staying NA, probably with a cam. I have a 3" aftermarket exhaust already. Which primary diameter should I get?
2010 R/T Classic 6M
For N/A I recommend 1 7/8
Reactions: Spartan040
I am running SW 2" on my 5.7 but it is running a PD supercharger and a 6.2 cam. The 2" give very little room for bolts.
2" primaries are to big, 1 7/8 are a better choice.
2015 SRT 392
I vote for the 1 7/8" ones. The bigger tubes work better on a car that is blown or a stroker motor turning some rpm's, but in a street driven N/A car, you want the exhaust velocity to be a bit higher because it helps with scavenging. If you want more low end and mid range power, then I'd recommend that you get the smaller header.
This vid may help your decision..
This vid and the one from engine masters comparing 2.5 and 3 inch exhaust along with dual vs X vs H pipe were enlightening.
Yeah its nice to see actual data.. I have Motor Trend on demand. I have watched all of the Engine Masters, some more than once. I was actually looking for the Engine Masters vid, but couldn't find the YouTube version so posted that one.
Sent from my SM-T350 using Tapatalk
Lol same here but literally binge watched all of roadkill & roadkill garage. Boost caboose still makes me laugh!
1 - 12 of 12 Posts
