#1...Is it safe to drive without the engine cover on? I like the look of motor without the cover.
#2...I was thinking of adding the open hood scoops from Speedlogix, just concerned about rain water,etc etc getting in. However, I think the SRT models have open scoops. Is there anything different between the aftermarket scoops and the OEM ones, such as a filter that blocks water from getting in to the engine bay?
Discussion Starter · #2 ·
Also, as a side note, i think I would have to take the hood liner off for the scoops to work:icon_confused
Discussion Starter · #4 ·
1. Yes its ok
2. I haven't noticed in water, but maybe more dust. You don't need to remove the hood liner.
Ok was just wondering about the hood liner because I do not see how fresh air would come in from the scoops, as in, there is no opening. So maybe the functional scoops wouldn't be worth it?
The scopes are more for letting heat out then bringing in air. If you look towards the back of the hood there are 2 rectangle opens. The functional hood scoped have ducts attached to them and thats where they exit it out
The openings are between the liner and the back of the hood (painted portion). There is two stamped rectangle shaped holes in that area which the back part of the scoop locks into. Whether or not it's worth it is totally up to you.
I just realized that I'm the slowest typer, ever.
