1 - 2 of 2 Posts
20% off last few bleeders in stock!
Using promo code TWUNNY, get 20% off our last remaining Chrysler/Dodge and Ford bleeders in stock. Offer ends when stock runs out. Click below to shop:
Now you can bleed hydraulic braking and clutch systems like the pros with a Motive Products brand Power Brake Bleeder. This unit operates just like the professional mechanics' tool - at a fraction of the price. Super high quality components ensure a long service life and a garage helper you can trust, time after time.
  • Easy one-person operation means you won't need to ask a helper to pump the pedal while you open and close the bleed valves.
  • Corrosion-proof design for years of maintenance free service.
  • Hand operated pump works anywhere - great for the home, shop, or track.
  • Two quart capacity assures even the most complex jobs go smoothly
This unit uses pressurized brake fluid to force air and contamination out of your lines and cylinders, so you'll get all the air out of your system the first time you bleed. No more bleeding and re-bleeding to get an air-free system.
Power Brake Bleeder for GM Ford Dodge Chrysler
To see a full listing of our brand new 2008-2010 Dodge Challenger items, please click here.
To see a full line-up of our current sales and specials, please click here.
1 - 2 of 2 Posts
