1 - 20 of 21 Posts
2011 SXT
Does anyone have good experiences with any of these Company's my Girlfriend want's to get me a Sequential Tail Light Wiring Kit for my Challenger for Christmas...
PFYC, RPI, Southern Car Part's... She asked how reliable are these places
Was going to get one through Yatesperformance but they have been out of stock for 2 months and don't seem to be able to replenish their stock.
They kit's all appear to look virtually Identical and most say only a Ground wire would be needed for my 2011...
Shame Mopar stopped offereing them id feel more confident with their kit.
Grille Vehicle Automotive lighting Hood Motor vehicle
Ha, I was one of the few that got the official Mopar kit, that they stopped selling due to too many failures. Mine is (knock on wood) still going strong..
2008 Challenger SRT8 #1101. 2005 Dodge Magnum RT AWD
I may look into these again myself.
Although I got replacement bulbs from Diode Dynamics in them so wonder if that make a difference.
Anyone know if they work with these LED's? I'm sending Webelectric a message asking also.
2011 SXT
Discussion Starter · #8 ·
Just looked over the Instructions for the Webelectric it shows using Wire Lugs and having to use splice connectors into the existing wiring harness I do not like that.
I dont like having to do this for various reasons...
I don't like having to do that either and like the fact that they advertised as Plug and Play except for maybe the ground.
I did not see instructions listed on their site but here's an excerpt from their page.
This is a true Plug-N-Play kit. You do not have to break off any rivets. There is no need to go into the fuse box to make any connections. Return to stock at any time without any evidence of ever being there! The kit contains pre-wired, plug-in harnesses that install with no wire cutting or splicing of any kind. (Note: 2011 and newer cars may need one ground wire splice) *
2011 SXT
Discussion Starter · #10 ·
Download the Instructions for the STS4 kit ... :( They even have a few pages showing different ways to hook it up depending on how you want the sequence to work when Braking ...It's more then Plug N Play. A ground is no biggie but if you have to go through other steps and splicing i'm not liking that.
Yep. That sux. Just located the install for it and it does indeed show cutting and splicing a couple wires.
I'd be interested in it if they'd just added a couple more plugs to their kit instead of adding splices / cutting.
Pliers Nipper Motor vehicle Paint brush Font
2011 SXT
Discussion Starter · #14 ·
As stated a single ground is not a problem but the instructions they have shows multiple splices depending on the Brake Sequence Pattern you want....
2014 R/T Classic 6-speed
I had the sequential signal kit on my '10 (previous owner mod - Mopar kit). It was fine, but I thought it looked a little "Mustang-y". Another way to go is what I did on my '14. I just swapped out the one-element sockets for two-element sockets on the deck lid portion of the tail lamps, and ran additional wires from the harness. Interestingly, the factory bulbs in the center portion are already two-element; don't know why. Now I have full-width brake and signal lights instead of just the ends in the quarter panels.
Not difficult to do, but does require pulling some wire from the trunk, and cutting the tail lamp harness in the center lamp. I did it right with soldered and shrink tube connections, and will pick up a salvage harness sometime when the opportunity presents so that I can put it back easily if I ever want to (which I doubt).
In my opinion, looks 100% better than stock, and mimics the '70 Challenger function for a more "retro" look. Also, the extra visibility doesn't hurt. Either way; sequential kit, or solid full-width lamps, it looks better than the factory set-up.
Cheers!
JD
2011 SRT8 392 BGE Supercharged Toxic Orange heavily modified Challenger
I am running the Mopar kit - and here is it 11 years later, and they are working just fine. Mine were installed when the car was new (at the dealer). They did a great job.
I think you have plenty of options. (And excluding looking like a "Mustang,, it'll be the best mod you don't actually see.)
Cheers!
JD
I may look into this. I like the sound of that better actually.
I Want More visibility but I also don't want it to look Mustang like.
Now to find the dual element socket part #'s...
How many did you end up using? 2 or 4 im guessing..
Sounds like you wired the center sockets in parallel with the outer edge ones?
Yup, I used 4 sockets; two each side of the back-up lamp. I'll PM you later on how I did the change and what all is required.
Cheers!
JD
1 - 20 of 21 Posts
