I have been reading and reading and am more confused then ever on what I need to do to my 2009 SRT8 w/130 Uconnect to swap to factory Nav? Could someone tell me what factoryNav radio will be plug n play?
If you already have the uconnect with mirror then you can get a 430N (RHB) and the cable that goes from radio to mirror and be good. If you didn't already have uconnect then you would need a 730N which has the uconnect module built in.
Before you go to the expense and trouble to install the GPS, you should know that the updates are $150 each and aren't that good. I just received the June 2014 release and it has some serious shortcomings. In my area, it is missing a state highway opened about 8 months, several business that have been around for years, include business closed for years and in some cases it has the wrong address. For example, it has an incorrect address for the Indianapolis Speedway, where the 500 runs. Its only been in the same place about 100 years. Somehow it has the Speedway confused with the stadium where the Colts. The facilities are 5 miles apart. This error was also in the previous "update". My Tomtom GPS is much more reliable.
