1 - 11 of 11 Posts
it will fit - the issue will be that the 2009 has a power steering reservoir. This impacts what air filter box will fit
Vehicle Auto part Car Engine Automotive exterior
the shape of the Mopar CAI airbox will not fit as the '11+ style coolant reservoir (and lack of p/s reservoir) has the space that allows this larger airbox.
The rest of the components - hood, shaker scoop, bracket will fit your '09 > you'll need to get the parts for the 5.7 as the 6.4 / 392 bracket is different.
I've attached my '16 Shaker CAI so you ca see the layout of the air filter box and the coolant reservoir that is used from '11 onward when the p/s reservoir tank was no longer used.
('11 - '14 had electro-hydraulic p/s and '15+ went to all electric p/s assist)
That helps, thank you!
Just throwing it out there for opinions. Will the 2016 challenger shaker hood kit/set up look good or not, on my 2009 Challenger? Hoping it improves the look and function.
2009 B5 SRT8 M6
That depends on what you classify look and function, post a pic of your car up, but I couldn't see it hurting, as for function, it may flow a bit better than the stock intake, but is mostly for show
What years had the pisser nozzles through the hood?
1 - 11 of 11 Posts
