I smell gasoline when I get in the car and detect it outside near right rear wheel well. The must be a gas leak in the system near top of the gas tank? I don't see any spill or leakage underneath the car. What is the cause?
Thanks Nuke. I took my Challenger to a local Dodge dealer. After putting it on the lift, they determined the fuel filler tube was leaking, especially when the tank was filled and checked again. The sock was wet. They advise to replace it with a new filler tube and gas cap. Unfortunately, they were not able to locate the part nationwide. It requires part # 4578989AB, which has been discontinued, and their search turned up none available. I had same experience online with ebay, MoparPartsGiant.com and others. It is a 2009-2010 part. Do you know of a source for the part?You can access the top of the saddle tanks by pulling up the rear seat bottoms. Check there for any obvious leaks. You'll probably have to crawl up under it and check the bottom of the saddle tanks for any obvious leaks too.
Have you recently run over anything like a curb or hit some road debris that might have come up and punctured the gas tank?
That's good they were able to identify the leaky part, but it shows discontinued on the local Mopar parts site i use too. You can hit up member @stevewhite on here to see if he can locate one possibly (his dealership is a supporting vendor here and they can be quite useful in helping resolve unique issues like this).Thanks Nuke. I took my Challenger to a local Dodge dealer. After putting it on the lift, they determined the fuel filler tube was leaking, especially when the tank was filled and checked again. The sock was wet. They advise to replace it with a new filler tube and gas cap. Unfortunately, they were not able to locate the part nationwide. It requires part # 4578989AB, which has been discontinued, and their search turned up none available. I had same experience online with ebay, MoparPartsGiant.com and others. It is a 2009-2010 part. Do you know of a source for the part?
The last option is to get it at a salvage yard, with no guarantees.
I did not run over a curb or otherwise damage the tank..
I would start with junkyards myself, if not a warranted part. The problem with car-part and junkyards in general is not ever (most) yards don't inventory every single part on a car, they will inventory typically body panels, drivetrain, and then interior based on color. Anything after that is a crap shoot. What I do, if I am looking for a specific part, I look for something generic like the rear window, that will probably be inventoried on just about every one, and typically intact. That will let me know of local cars, then just online chat/email/call them and ask for the exact part you need...I did a quick search (using car-part.com) for the fuel filler tubes just to see how easy they were to find at a salvage yard and how much they are asking for them, and i was a little surprised at the results. It returned a total of 10 in all of the US, but the prices were all reasonable thankfully. So if you end up going that route, it looks like you won't have to pay thru the nose at least...one positive in all this mess![]()
Thanks A Guy! I was able to order it from MoparPartsGiant.com, today. Oddly, I called them a couple days ago and they didn't have it. Discontinued. Go figure.Amazon.com: Genuine Chrysler 4578989AB Fuel Filler Tube: Automotive
Buy Genuine Chrysler 4578989AB Fuel Filler Tube: Fuel - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
4578989AB superseded 4578989AA, you can include that in any searches
4578989AA - Genuine Mopar TUBE-FUEL FILLER
MoparPartsGiant.com offers the best deal for genuine Mopar parts, 4578989AA. TUBE-FUEL FILLER. All parts are backed by the Mopar's warranty.www.moparpartsgiant.com
Above doesn't say discontinued, but I'd call them
The replacement part is # 4578989AA. I'll call again to verify it is an accurate part.Thanks A Guy! I was able to order it from MoparPartsGiant.com, today. Oddly, I called them a couple days ago and they didn't have it. Discontinued. Go figure.
Bummer, it came back as discontinued! I'm still looking for one.4578989AB superseded 4578989AA , they didn't have it under the newer number, but they did under the older number. Same part. Glad they actually had it, let us know how it goes
https://www.moparrepairconnection.com/wdportal/xls/SupersessionList.xlsx
I can't locate a new part, so looks like salvage yards is a possibility. Hopefully I can get one locally.I would start with junkyards myself, if not a warranted part. The problem with car-part and junkyards in general is not ever (most) yards don't inventory every single part on a car, they will inventory typically body panels, drivetrain, and then interior based on color. Anything after that is a crap shoot. What I do, if I am looking for a specific part, I look for something generic like the rear window, that will probably be inventoried on just about every one, and typically intact. That will let me know of local cars, then just online chat/email/call them and ask for the exact part you need.
