I have a 2010 Challenger RT with 26,000 miles. The pilot bearing when out damaging my clutch assembly, which will have to be replaced. I do not yet know if the Tremec TR-6060 6-speed transmission is damaged. I have checked around and have been unable to locate an industry rebuilt or new transmission and only one high mileage used one. Are these transmissions for a 2010 Challenger unavailable? Any alternatives or suggestions?
Thanks!
you should be able to use a 2009, 2010 or 2012+ Tremec. only the 2011s had a different input shaft spline count (10 splines), then went back to the 26 spline style shafts.
Your 2010 isn't unique compared to the other years
About the best you can get. Will be the last one you would need
Sent from my SM-G960U using Tapatalk
I too english well speaking...
Read this outloud - "A Core Charge will be charged if you do not have a Charge of $1800.00 will be charged if you do not have a rebuildable core to return rebuildable core to return "
Thanks!
Tick Performance rebuilds our transmissions.
