If the car come with the 430 (w/o nav) media center, is it a pretty straight fwd procedure to switch to a 430N or 730N?
Thanks!
Thanks!
It is pretty much plug and play. I changed my 130 to a 430 and it went very easily. The N has an extra connection for the nav antenna but it should be staightforward.If the car come with the 430 (w/o nav) media center, is it a pretty straight fwd procedure to switch to a 430N or 730N?
Thanks!
Have to buy them from the dealer, there is also a process to installing the 730 that you needs to be done at the dealer.Is there a website that sells these (besides the stealership)?
Doesn't look like there's that carries these as everyday products..
I am looking for these specifically,
RHB-430N
RHR-730N
You can buy both units from these guys: 430N and 730N. Send them an email with your VIN and they'll let you know exactly what needs to be done with your car to upgrade the factory unit to a new MyGig, including GPS antennas, uConnect pieces, microphones on the rearview mirror, or whatever else.Is there a website that sells these (besides the stealership)?
RHB-430N
RHR-730N
If you already have uConnect you probably won't need this stuff, but send those guys your VIN anyway and make sure.Hey, thanks, that's who I have found as well... i don't think i would need the uConnect or microphone as the car is built with Sound group 2.... does this sound about right?
FYI that is a different radio, That is the RER Radio not the RHR.You can buy both units from these guys: 430N and 730N. Send them an email with your VIN and they'll let you know exactly what needs to be done with your car to upgrade the factory unit to a new MyGig, including GPS antennas, uConnect pieces, microphones on the rearview mirror, or whatever else.
Otherwise you can find used units on eBay pretty easily as people pull them to install aftermarket units.
Thanks for the info. From what it looks like, the MyGig radio installed in my 2009 SRT is the 730N. However, I remember someone saying that this radio can stream audio via Bluetooth and I don't think that my radio can do that unless it depends on the type of audio device being used, i.e. iPhone.
