Was thinking about swapping the old touch screen w something more 2000+. Lol. Anyone have a how to on that or is it pretty straight forward w a wiring harness like back in the day?
2012 Dodge Challenger R/T Classic
It’s easy. Go to Crutchfield and fill out what fits your car and audio setup. My 2012 needed the PAC harness/interface, antenna adapter, USB adapter, and metra trim kit. I also added a rear camera. After the install, I wasn’t happy with the speaker-level feed to the factory amp, so I also added a line-level converter.
j
j
I have the SRT w the factory Kicker setup. Probably just contact them to make sure I get the right adapters etc. thanks for the info.
If you’re adding a backup camera, buy this (it replaces the license plate light perfectly but you’ll have to wire tap the existing light harness for the plate light to illuminate):
Discussion Starter · #5 ·
Idk if I care to do that yet but where does the line level converter plug into? I may do that just to avoid messing w it later.
Between radio speaker output and amp harness speaker input. It gives you a gain (level) control b/c the amp’d radio output is too hot.
