1 - 4 of 4 Posts
How difficult is it to replace the radiator? What is the procedure? And is it necessary to take apart the entire front end of the car to do so? Thank you.
Pretty sure you will have to drop the fascia or at least that will make it easily to replace. I have a same as new radiator from my '10 R/T I will let you have cheap if you want. Nothing wrong with it just replaced a lot of my cooling system parts with SRT parts when I upgraded my SC and went with more boost.
You might check out Speedy's Garage, he has a ton of how to video's.
Thanks for the tip! I'm fixing to drop a Fluidyne in mine when I install the Magnuson. :grin2:
1 - 4 of 4 Posts
