1 - 2 of 2 Posts
When I flip to high beam drivers side goes out. If I dlash the high beams drivers side comes on & goes out immediately.
Swap the headlight bulbs from side to side and see if the behavior stays with the driver’s side or follows the bulb to the passenger side.
If it follows the bulb, the bulb is faulty and should be replaced.
If it stays with the driver‘s side even after the bulbs are swapped, the problem is NOT the bulb.
Reactions: A Guy
1 - 2 of 2 Posts
