1 - 4 of 4 Posts
anyone know if the 2008-2010 skip shift eliminator will work on the 2011's?
is it something you can do without jacking up the car?
I can't comment on the 2011 cars, but you will surely want to jack up (at least) the left front wheel to gain access to the transmission plug.
There's just no way to connect the skip shift adapter without lifting the car.
There's just no room to get under there and get a hand up and around the transmission to make the connections.
I think he meant "jacking up" the car like "screwing up the car" in case the skip shift eliminator wasn't compatible.
I wish I knew the answer huggytree. I THINK/hope it is, since the tranny didn't change, just the PCM, so it should look for the same voltage unless they decided to change the solenoid as well (which it seems like we would have heard about).
I was confident enough to buy an eliminator (and my '11 is still sitting in windsor as we type)...but I can't guarantee it will work.
1 - 4 of 4 Posts
