41 - 60 of 132 Posts
Got off the phone with the dealer. The additional part that covers the fender gap is part #.
I'm gonna go in and check it.
Air Dam Support
68024342AC -driver side
68024343AC -passenger side
$21.26.... a piece.
Before u order these numbers, look at pic in parts book.. I think it is wrong no.
Check out p/n: 668109838aa & 9839aa. About $9.85 ea
I agree with 1BADSRT...
Parts in hand and verify: 68109839AA LH
68109838AA RH
These are the two "end caps" if you will ,that finish off the spoiler at each lower end.
Also, there is : 68086604AA RH
68086605AA LH
These are the duct inserts that fit just inside the brake duct opening on each side. Not sure if they are needed to install, or if they can be left off of R/T installation.
Plan on doing this soon myself....:thumbsup:
I wonder if leaving the lower gap open would benefit airflow for the intake. Maybe help with pulling out underhood air at speed while allowing fresh air to access the fender well. Not sure what kind of pressure zones we are looking at in the wheel well. Just a thought, but dunno how this could be tested.
On a similar note, the car does seem to handle a bit better on the highway and so far, no issues with the new spoiler.
My friend at the Dodge dealer is looking up the parts and ordering them for me now.
________
Live sex
I placed the order for the first part numbers you posted, I will have to cancell the order and use the correct PNs; I payed $42, do you know if they refund the complete price?
Part #'s
2011 SRT8 Chin Spoiler:
68109837AA
Fender Gaps:
68109839AA LH
68109838AA RH
For R/Ts, you'll also want to get the SRT8 belly pan so you'll have functional brake scoops.
SRT Belly Pan with Air Ducts 08-09 Challenger
Also, there is :
68086604AA RH
68086605AA LH
68109837AA
Fender Gaps:
68109839AA LH
68109838AA RH
Also, there is :
68086604AA RH
68086605AA LH
You are three shades of bada$$. Thanks for the contributions on this thread!
Rayzazoo, what type of ramps are you using? and how far off the ground are you getting with them?
68109837AA
Fender Gaps:
68109839AA LH
68109838AA RH
Also, there is :
68086604AA RH
68086605AA LH
I installed mine today, it is mnot easy and I spend about 2.5 hrs; by the way I did not modified thenew spoiler and 2 of the holes did not aligned and left them like that. You will have to remove the belly pan that will make the job a lot easier
I just finished mine as well. I had a KB SC radiator in the way so I had to pull the bumper off, not enough room to get to screws.. The install went very good.. No trimming on spoiler at all except for on the screw tab in the lower part of the spoiler near the middle, I cut it off through middle of the hole in the tab on the spoiler, then put metal clip on, then drilled small hole through tab in new spot and ran screw through new hole and clip. This went very well. You will need new plastic Rivets however for the wheel well or you could go to your hardware store in the pull out tray section, like I did and get the push in rivets (re-usable ones) like the rest of them in the wheel well but a little longer.
I to have the open hole in the wheel well and hope it is an easy fix like a small piece shown in picture. I did notice some new holes that weren't used in the new spoiler near the opening where the missing piece needs to go, I guess those are for the missing piece. I hope I don't have to replace the wheel well liner to fix the issue. Keep me posted
BTW: I had no problems with my original belly pan on the SRT as it match up.. I just has some extra push rivets and two small screws and one medium size screw with an unusual washer on it left over for some reason, go figure?
68109838AA RH
68086605AA LH
My install took about 5 or 6 hours (including 2 trips to the hardware store and a lunch break) as I have to pull the front bumper due to other equipment I have behind the bumper that was in the way. (I just can't figure out where the extra left over screws and fasteners go now that I have it back together)
I guess each car/spoiler must vary a little as all the holes lined up on mine except for the tab which I modified and got the screw and clip installed.
My 2 additional parts have arrived at the dealer and I will pick them up when I return home from work in a few weeks.
I also picked a cheap plastic rivet gun with a few plastic rivets to replace the rivets that I has to cut to get front end and fender well loose.
I would love to see some pictures of the last 2 parts ordered and see what they look like on someones car as well as some pictures of your completed cars now that they are finished.
I used a set of ramps I picked up from autozone. It lifts he front end about 1-2ft off the ground. I use these for oil changes too.
What a Pain in the A$$ getting the old spoiler off ............. Take your time, I did find one broken part from the factory but it can be fixed
will have pic in a few days.
I think the 2011 SRT spoiler is an improvement over the previous years, but I don't think it is worth the money/hassle for the 08-10 SRT to switch. The 08-10 SRT spoiler looks just fine. Either one is a nice up grade for the RT, however.
^^^Your opinion, although subjective. I for one have ordered the parts and look fwd to the install.
I have a Kenne Bell SC on as well so I might run into some problems too. I don't mind though as I need to remove the front bumper anyway for other modification to the bumper itself.
