2015 Scat Pack
First off let me say that I have been searching on here for the last hour to see if I could figure out what I'm doing wrong with no luck...so I'm starting a new thread asking how to access my Hidden EVIC screens.
I have a 2013 6-spd R/T with STP. No other options. So I do not have the electronics convenience package (no compass on my outside temp screen).
I have tried accessing the hidden EVIC screens with no success. I have tried with the car running as well as with it just in accessory or ignition mode. The process I have followed is while on the screen with the outside temp I have held the up arrow button on the left hand side of the steering wheel down for anywhere between 5 and 25 seconds, and then released the up button and proceeded to hold the down arrow button as long as 30 seconds with no success.
Am I doing something wrong here? From what I've read the screen should change while you're holding the down arrow. Has anyone else with 2013 been able to access these screens?
2015 Scat Pack
I have a 2013. There is not a musical note or compass button.
2015 Scat Pack
I'll give it a shot!
Update, did not work.
I have a 2013 R/T w/ no compass as well. I did get it to work using the up and down buttons. I pressed the up button for a hard 10 Mississippi count and quickly pressed the down button and held it until the EVIC screen changed. I believe I had the engine off but the ignition in the run mode (hit the start button twice without pressing the brake).
I have a '13. Car can be turned on and in D as long as the car is stopped, and using the up/down as noted above, works like a charm. However as soon as the car is shut off, you have to re do steps if you want the hidden menu back on.
