Hello!
The previous owner of my 2013 Rallye Redline Challenger replaced the OEM halogen headlights with LEDs, but wired them in a weird way. Currently, they are wired to the jumper cable port attached to the fuse box in the engine bay. I’ve started to have problems with the passenger side headlight going out and I can’t figure out what the issue is.
Initially I thought the issue was the relay overheating and shorting the light because it would turn on when the car was cold started, but would not turn on if the engine was at temperature. Now, it will turn on if it’s the first time the light is turned on for the day (ie, parking in a garage), but will not any subsequent time until an extended period of time between powering on. And when it does turn on it only stays on for a few minutes before turning off.
Really what I would like is to replace them with OEM headlights and have them wired through the fuse box again to save problems when I trade it in, but in the meantime I just want my headlights to work. Any thoughts/suggestions are appreciated! Thank you!
