1 - 3 of 3 Posts
Hi guys so I my Challenger has the air bag light on and I was looking to see if anyone has experienced the same thing or may know why it is happening. If so what did you do to fix it or what should I do. Thanks !
Welcome to Challengertalk adrians56. The easiest thing to try is disconnect the negative battery terminal for 15 minutes or so. reconnect, and see if Airbag light remains. A Guy
If that doesn't work, you will need to have the SRS system scanned, preferably by a Dodge dealer.
Most SRS components need to be replaced if not functioning correctly, none of them can be repaired, some things can be reset.
And this can really be anything from under seat wiring, clock spring, bad occupancy sensors and so on...
1 - 3 of 3 Posts
