I have a 2014 Challenger RT, can anyone tell me (or show me via youtube or other video) how to change out this bulb?
thanks AJ
You will need them cheap trim removal tools from Harbor Freight. I found some photos online on showing how to do it, but you don't need them.......you will turn your wheel in, pry out 4 or 5 push in fasteners at the front, then pry the wheel well inner back. Take a peek in the with your flashlight and look for the wire bundle and housing. Twist it out and there's the bulb. While you are down there, you might as well swap them out for some LED's from supporting vendor Diode Dynamics! http://www.challengertalk.com/forum...d-bulbs-upgrade-your-lights-plug-play-201562/
Thanks! Is there any way to make these Day time running lights while I'm at it?
thanks AJ
Just replaced mine with Diode Dynamics XPS80 bulbs. There are 4 reusable plastic fasteners per side. The bottom one is slightly different. Probably 5 minutes per side. These LEDs are extremely bright.
