Does anyone else here have a trunk release button on the outside of their Challenger? Mine is on the back right below the 2nd D in Dodge. If anyone does, how can I disable it? Kind of weird that just anyone can open the trunk, even when the car it totally locked. Anyone?
The outside trunk button started with the '11 models.
Yours may not have had the software flash to correct the software issue.
With the fob at least 10' from vehicle - and the doors locked, the trunk release button (exterior) should not allow you to open the trunk.
If the doors are unlocked, yes the exterior release button is active
If yours opens with doors locked and fob not in proximity, the dealer will probably need to flash the system with updated software to correct that.
Yes, my 2016 has the exterior trunk button. No need to disable it. You have to have your fob with you for it to work.
