1 - 3 of 3 Posts
gps off by around 10 miles and no xm just says aquiring signal 8.4 screen with nav anybody had anything like this problem
This is still the 2015? Other than no XM signal, and the GPS being off ten miles, everything else works? Might try resetting the radio. if you do this, choose RESET RADIO not RESET TO FACTORY DEFAULT
You could also try the tried and true unplug the negative battery cable for a few minutes
try resetting radio and reflashed radio same problem,i belive its either radio,gps antenna, or wiring issue
1 - 3 of 3 Posts
