1 - 12 of 12 Posts
Discussion Starter #1 (Edited by Moderator)
Now available and ready to ship ...
To order: Eibach Pro-Kit Lowering Springs 15 Challenger SRT, Hellcat
Eibach PRO-KIT is the perfect answer for most frequently-driven street cars. It's our legendary spring system that dramatically improves both a vehicle's performance and appearance.
PRO-KIT lowers your Hellcat's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach PRO-KIT is the finishing touch to a winning recipe for performance. PRO-KIT also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach PRO-KIT is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, PRO-KIT provides the ultimate balance to take your passion for driving to a whole new level.
Approximate installation time: 3 hours
FRONT:
OE rate: 55 N/mm (314 lbs/in)
PRO-KIT progressive rate: 40 - 66 N/mm (228 - 377 lbs/in)
Bump-stop: OE
Damper: OE
Tubing: Yes
OE wheel center to fender: 397 mm (15.6 in)
PRO-KIT wheel center to fender: 369 mm (14.5 in)
PRO-KIT can be aligned to OE Specs: Yes
Front Alignment:
OE Camber = -1.1L, -1.4R deg (+/-0.6 deg)
OE Caster = -0.7 deg (+/-0.6 deg)
OE Toe = 0.20 deg (+/-0.10 deg)
PRO-KIT Camber = -1.6L, -1.9R deg (+/-0.6 deg)
PRO-KIT Caster = -0.9 deg
PRO-KIT Toe = 0.10 deg
REAR:
OE rate: 136 N/mm (777 lbs/in)
PRO-KIT progressive rate: 55 - 164 N/mm (314 - 937 lbs/in)
Damper: OE
Bump-stop: OE
Tubing: N/A
OE wheel center to fender: 416 mm (16.4 in)
PRO-KIT wheel center to fender: 387 mm (15.2 in)
PRO-KIT can be aligned to OE specs: Yes
Rear Alignment:
OE Camber = -0.8 (+/-0.6 deg)
OE Toe = 0.20 deg. (+0.15 deg)
PRO-KIT Camber = -1.1 deg
PRO-KIT Toe = 0.17 deg
Approximate installation time: 1 hr
On the alignment figures - you've posted the front figures twice, do you have the rear figures please?
1 - 12 of 12 Posts
