Hello,
I know all of you are aware that the headlights on the Challenger are a nightmare. I contacted Morimoto asking for recommendation and they suggested me their 9012 Morimoto Elite HID system. Have anyone used it? Have you tried anything else? Are you happy with it?
I used the 9012 2Stroke LEDs and was pleased with them. Drop in, fit in the housing, and a big improvement.
Edit: FYI, I still have a used set in a box I'd part with.
Hello,
What's so bad about the factory headlights? I have had my headlight assembly removed and taken apart 4 times (that's including being baked in my oven with bulbs/module attached) and I have not had any issues with them. Although I will say, the headlight power distribution (at least on 2015 models) is very sensitive (more like screwy) to additional loads...especially the park/side marker power lines.
Discussion Starter · #4 ·
I mean that the visibility during night is horrible. They are not so bright. For comparison the Camaro has really nice headlights if opted out properly.
I recently did the H7 to H9 upgrade on my low beams because of how crappy the low beam visibility is at night, and I couldn't be happier. Now yours aren't going to have H7s for low beams like mine, but if they are they the straight based version of the H7s, I bet there are some straight based alternatives like the H9s. If so, I'd try them. You're basically replacing the low beam bulb (a 55w halogen) with a hi beam bulb (65w halogen), so it won't be a direct plug in, but you just have to trim a little tab inside the plug of the bulb to get it to work.
n/m, disregard my reply. I forgot the challengers have the low and high beam on the same bulb.
Hello,
I have a 2016 and they aren't the best headlights for sure. I've always had great performance from the Hella High Performance 2.0 bulb and the Sylvania Silverstar Ultra, which I have for both the headlamp bulbs and fog lamps. I've had them in since I purchased the car in January, 2016 and haven't had one blow out or any other issues. The light output is much better. At the time, Hella didn't have a 9012 for the Challengers and I haven't checked to see if they have manufactured any since then. I believe for the money, availability, and ease of installation, they are a good choice. If a bulb light output is "too white," you'll lose visibility.
