I have a '15 r/t + classic pkg with stp. What is the max size of tire /wheel size I can use without any mods? Any recommendations for aftermarket wheels similar to oem heritage wheels? Thanks in advance!
You are limited with your 8" wide stock wheels. You can move up to 255/45/20 tires, but I'm not sure that will have much of a visual effect as being an improvement. I can't answer your second question, sorry.
Thanks for your reply
If you plan on aftermarket wheels, you can do 9.5" in front with 275/40, and up to 10.5"-11" in the rear with 305/35 or 315/35 (315s may require a slight wheel well plastic massage). All assuming the right offset on wheels. The various available replica wheels have the correct offsets
Thanks, that is the info I was looking for.
I have 8" stock R/T plus rims and I was able to fit 275/40/20 all around, but needed spacer in the front to avoild hitting steering control arms (I also have Mopar stage 1 lowering springs)
Reactions: Steve E
Hellcat wheels will fit, they are 20x9.5 with an 18.5 mm offset. With these you can run 275/40 in front and 295/40 in rear.
Reactions: Steve E
275s will physically fit on 8" wheels...however, not a recommended fitment
Reactions: Steve E
Running 9's in the front with 1/8" billet spacers from speedlogix. Hard to fit much bigger than that before hitting the spindle
