1 - 13 of 13 Posts
My 2010 SE Rallye was recently murdered by a Toyota Tundra.
I ordered a 2015 R/T+ (or is is SXT w/RT+...stupid naming convention...) with Supper Track Pak, Phantom Black, Automatic (daily driver, don't want to deal with a manual in heavy traffic) on 7/24/14. I'm in Arizona and there aren't any 15s here yet that I've seen but it appears they're popping up on the right side of the Mississippi. Hopefully mine will be here soon (VOTS says D1 but I'm living in denial and refuse to believe that...ship date was listed as 8/14/14).
I'm not really a car guy but my entire family are all Mopar fanatics yet we can't find out much about various details. While ordering I had questions and we couldn't really find answers for them at the time so I'll ask here:
20-Inch Hyper Black Aluminum Wheels. Any idea exactly which ones are on the Super Track Pak? The Google fails me.
STRIPES! The brochure had 6 or 8 different styles listed but no pictures. Once again The Google failed me. I ordered w/o stripes. Does anyone know what the stripe options look like on the 15s? I might slap some on later.
The Super Track Pak had a different rear end/axel if I recall. What's the difference between that and the standard configuration?
Anything else on the Order Confirmation that can be deciphered would be appreciated. This site has been a great resource so far, thanks for sharing the knowledge in your motorheads!
Go on the "General, performance, Technical " thread then go on '15 information.
The second posting will give you EVERYTHING you need to know on the '15's, there are a couple of PDF's that will give you dealer order codes, standard & optional equipment broken down for each model, very helpful.
Sorry to hear about your car! I'm in AZ also, which dealer did you order your '15 from?
These are the wheels you get with STP, called Hyper Black although not really that black at all.
Land vehicle Vehicle Car Motor vehicle Muscle car
Only optional factory installed stripe on base R/T is the M24 Modern Hood Stripe.
Land vehicle Vehicle Car Hood Muscle car
This pic also gives you another look at the STP wheels.
On R/T should be no difference in rear axle, on SXT you would get a 3.07 in place of the 2.62 but R/T already has the lower gear.
Damn, sorry to see your SXT in that condition, but moving up to a '15 isn't a bad consolation. You make it out ok?
Discussion Starter · #5 ·
Thanks. I've seen some PDFs and that's what caused all the head scratching. Didn't know about that thread, I'll check it out.
Tempe Dodge.
Slidd Thanks for the pix!!! I had found pictures of those wheels but only a black and white outline type of thing.
RoodyThat car saved my life. If I was in anything else I'd be a heck of a lot thinner right now. It was a no brainer to get another Challenger.
Per the Dodge PDF supplied by Resume Speed, R/T Plus w/8 speed auto:
Super track pack AWD, 20x8 hyperblack wheels WSQ, 245/45-20 perf tires-Goodyear spec, antilock 4-wheel disc HD brakes BR6, dodge perf pages, perf steering SBP, sport suspension SDE, steering wheel mounted shift.
It appears the 8 speed w/STP will have the 3.07 ratio but doesn't clearly state if it comes with Anti-spin diff. DSA like it does with the 6 speed. It "appears" to still be an option.
Hope this helps some.
This is exactly what I'm trying to find out. I'm still waiting for a call from my dealer for this info. If the 8 speed doesn't get Anti-Spin differential I will install a Detroit Truetrac to help during winter driving.
I don't think any 5.7L automatics will have anti-spin, either standard or optional. They might even have the same open 195mm 3.07 from the SXT.
Edit: The R/T will use a 230mm rear axle.
A wrecked Challenger is bad news, but a saved life is good news. Glad you trust the car with your life!
My build sheet emailed to me from Chrysler for my RT Classic w/ STP states: 3.07 Rear Axle Ratio 230MM Rear Axle.
It does not have the non slip diff. That is reserved only for the SRT models.
Thanks for the info. The only reference to the 230mm I could find for R/T was for the 6-speed. I do think though that the Scat Pack cars will also have the limited slip 230mm.
1 - 13 of 13 Posts
