1 - 4 of 4 Posts
Hello I have a 2015 scat pack challenger that’s overheating with no coolant leaks replaced the thermostat but I did not help fans are running fine still overheating any help would be greatly appreciated
Sure the weep hole on the thermostat is positioned at midnight?
How hot is it getting? Sure you are not looking at oil temp?
No sure it was temperature when warning came on was at 3/4 shut it down put new thermostat in same position original was in
There have been a couple of folks here who installed a new thermostat only to find out the new one was bad (most were the 180F thermos though). There should also be a plug (although I think the SP has a hose and not a plug) to bleed the system.
Make sure you don't mix OAT & HOAT antifreeze as it will generate sludge.
Are you hearing any noises from the water pump? It is not uncommon for the bearing to go out causing the impeller to be chewed up.
1 - 4 of 4 Posts
