All oem parts that were taken off the car @ 2,400miles. I installed a procharger and some goodies. This is what was removed. All items are best reasonable offer.
Includes:
32mm 10lb Hallow Sway Bar w/Bushings $100
Shaker airbox assy (no maf) $125
Fuel pump w/oring and lock ring $50
Injectors $100
Map sensor $25
Radiator Shroud and Lower Guard $50
Brake Ducts From Bumper $20
Driver Side Shroud $5
Idler Pulley $5
16 Spark Plugs $50
Belt $25
Center Caps $25
Sunglass Tray $5
2x Scat Emblems $40 for both
2x 392 Hemi Scoop Emblems $40 for both
1x Dodge Rear Emblem $20
Any offer will be considered.
Thanks for viewing. Text or call only please 262-719-5013. Erik.
The airbox is from a shaker. The tube is for the shaker to the hood scoop. It does have the hole in the front though if you wanted to buy a hellcat headlight duct separately and cap the scoop hole.
