1 - 2 of 2 Posts
I added oem fog lights to my car had the dealership add the sale code now when i hit the head light switch the fog light icon comes up on the dash.
I ran the harness to the inside of the car at the firewall found the two plugs where the two wires get attached to the I guess it's the PCM ?.
Plugs per the directions that came in the oem kit.
But I only have 2mv at the fog light plugs not 12 volts i'm thinking I need there but when I turn on the fog lights just one flashes 2x and then stops does not come on.
I put the ground wire where it said to attach to.
Any help would be apprecated thanks
The low voltage you noted definitely seems like the problem, but why they’re not getting proper voltage is now the mystery.
I am curious about the ground wire statement, was it not part of the included harness that plugged into factory harness?
1 - 2 of 2 Posts
