I have a 2015 Challenger SXT Plus, the original tire sizes are 245/45r20 99Y on both the front and back.
My question is, what is the biggest size I can install on this model?
Thank you
Welcome to Challengertalk Sebastian. On the stock 8" wide wheels, 255/45 is the widest suggested size. People run 275/40s on the front with 9" and + wheels, with the right offset. They will also ft on the back. People have managed 315/35 on 10.5" on the back with the correct offset and tire make.
If your question was on the stock 8" wheels, moving from 245 to 255 will not net you much, and will further limit your overall tire choices.
A Guy has given you some great advice.
With the stock 8" wide rims you can't really do much that will make a visual impact. Do you have plans on going with wider rims, be it Mopar, or an aftermarket rim?
In my opinion, the best thing you would get from the 255 is a bit of additional rim protection with a slightly wider bulge. If you are in need of tires, and the brand you want comes in 255, I can think of no reason not to get them over the 245.
