1 - 11 of 11 Posts
Hello everyone,
I'm looking to buy a 2015 SXT plus from a dealer so I test drove it yesterday and I noticed one thing, when you change from N to D or R or vise versa the car jerks, nothing when shifting gears, it's only when the car is stopped, is that anything more than a driveshaft coupler ?
Anyone have this before ? Or know anything about it ?
Should I proceed with the purchase or it might be a transmission problem ?
Thank you
I would see if they will let you take it to your own mechanic for an inspection. Very well could be the drive shaft center coupling or excessive backlash in the differential. If the dealer won't let you get an independant inspection, I would pass on acquiring this car.
Idle speed not excessively high?
Normal. It may lessen if you give the car a minute to warm up and the RPMs drop.
Reactions: F.Majdalz
FWIW the 2015s had a few TSBs on transmission
994480
One dealt with shift enhancement.
994481
You can find full TSB listings thru chiltons.
Yes, it's only when the car is idle, when you are driving there's nothing jerking. Only when the car is stopped and you put the gear to D or R that moment when the driveshaft change the direction
I think this is more advanced than what's happening now, because as I mentioned there's no problems when shifting, it's only when the car is stopped and you put it to D or R.
But thank you for the information ! I'll keep it for the future
That's why I asked if the idle was excessively high, causing it to jerk when put into gear...I know computer controlled cars should know, but then again, they shouldn't jerk...
No idle is normal...
I know others have mention jerky shifts when cold, but your issue sounds different perhaps
1 - 11 of 11 Posts
