I changed the battery after tint place killed the battery after leaving the doors open. So i changed the battery and when i drove off the rear and front lights started to flicker also the radio outside ambient temp read -40 degrees. I took the Hellcat to the dealership after owning the car 5 days....not happy. What could be wrong?
Sent from my SM-N950U using Tapatalk
I don't think this is a big deal. If the tint shop killed your battery, then all the electronics have to find themselves again and reset themselves. Did you drive the car long before you took it to the dealer?
Turned out the BMC went bad just my luck but still under warranty.
Good deal, glad it's getting worked out. These cars can do some whacky things when the voltage gets low.
I hesitate to ask but what's a BMC? :|
EDIT: I think I may have found it. Is it BCM for Body Control Module?
