1 - 3 of 3 Posts
2019 Dodge Challenger RT Pitch Black Clear-coat
Discussion Starter #1 (Edited by Moderator)
Hey all, my first forum thread!
I was recently looking over some different modifications I could afford and I haven’t seen too many, if not any, cams for the 5.7. Is there a reason for this?
If there are cams available for the 2019 Challenger R/T? I’m hoping the Mopar gang can help me out, unless you have other suggestions for power gains that are better for the budget.
Picture of my Challenger below.
there's a number of choices out there - Comp Cams, Modern Muscle Extreme. The pitfall to avoid is going with too much cam - look at the effective rpm range the maker recommends and that guide which direction to go.
for example there's the "274" Comp cam - its operating range is 3k - 7k rpm which isn't suited for a primarily street driven vehicle plus not recommended for a 5.7. its intended for larger displacement engines.
more is not always better is the watch word. Many of them, for A8 applications are going to require non-MDS lifters if you have the A8...add in the labor and parts, and it can add up.
that being said making the 5.7 breathe better - cam and good tuning will really wake up the 5.7
1 - 3 of 3 Posts
