Smelled a little burnt oil yesterday then saw a small drop on the garage floor. Put the car on ramps and took off the plastic shield to inspect the filter. Saw a little oil on the outside surface of the filter but couldn't tell where it was coming from. Wiped it off and made sure it was tight. I changed the oil at 1500 miles and was conscious about making sure the oil filter seal was not stuck to the block. After more visual inspection tonight I noticed a small oil stain on the passenger side valve cover. It also looks like there's oil residue between the small covers and both valve covers. See pic. I plan to get it back to the dealer.. is there any need to take my catch can off and put it back to stock?
I've done a few searches.. anyone else seeing leaks around very low mileage 6.4s?
Thanks
Thanks
